Which memcal to get
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Caleb dawson, Nov 24, 2018.
  1. Caleb dawson
    Caleb dawson Member
    Glen innes
    1994 vr executive
    I found the performance memcal on the mace websight I'm just not sure of what option to chose there is vr (early),and vr (late),how do I figure out if my vr is a early or late model? And do these memcals provide a decent difference to how it runs
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    When was ecotec released? Before that was the buickV6.
    Or if auto, was early a TH700 which had no ecu control, and later was 4L60E full electronic trans.
    What year is yours?
  3. Caleb dawson
    Caleb dawson Member
    Glen innes
    1994 vr executive
    Its a 94 vr,my problem is on the sight there are options for vr(early) and vr (late) and I'm just not sure I've mine is an early or late model vr
  4. Caleb dawson
    Caleb dawson Member
    Glen innes
    1994 vr executive
    It's a 94,on the id plate trans says m30 if that helps
  5. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Nov 94 up to april 95 VR's had the hdd 5 trans(same trans that was later fitted to the first run VS) which had tcc lockup, the earlier models didnt....
    edit ps
    If your vin number is higher than L772126 then its a late model memcal, if its lower its early
  6. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Mine has the 4L60E and it is an early 94. Build dates after Nov 94 are late trans.
  7. losh1971
    North Tas
    VR Ute V6
    What does TCC lockup mean? Because mine is an early and it has torque converter lockup.
  8. Wozza
    VR_GS commodore
    I think its electrical(Pcm) controlled rather than pressure speed controlled ....but I know stuff all about trans so could be wrong ;)
  9. losh1971
    North Tas
    VR Ute V6
    Ok yeah mine works through the valve body when it changes up. Early VR ones still have the same part but somehow it does operate differently. I had an issue with error TCC that I had to ask the trans tech about but it has since gone away.
