Which Multi Meter
Punter68
morphett vale
VT Series 1 Executive wagon
Hey guys and gals. can anyone reccomend which sort of multi meter i should purchase to check what I need to on a vt commodore.
So many choices not sure of what I should be paying to get the job done.
your advice appreciated
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Actually good question
I too would only use it for basic stuff. Kmart special suffice?
Sent from my HTC ARIA using Tapatalk II.II.IV
Punter68
morphett vale
thanks Mick if you have purchased roughly what was the budget
Rapid Mick
Western Sydney
VX V6
Look after it and a multimeter will last for years.
Here's one for $59.95.
http://www.jaycar.com.au/productView.asp?ID=QM1444
Automotive DMM with Inductive Pickup
A multimeter for all your automotive diagnostic needs. Features an inductive pickup for RPM measurement, dwell angle, frequency, duty cycle, data hold, relative function, backlit display and temperature, and works with engines of 2 to 10 cylinders. An absolute must have for the backyard mechanic or qualified tradesperson alike.
• RPM x1, x10
• Inductive pickup for RPM
• Dwell angle
• Resistance
• DC volts
• Temperature
• Frequency
• Duty cycle %
• Data hold and relative function
• Probes, alligator clip probes and holster included
Darren_L
Toowoomba, Qld
VH SS
yeah as above Jaycar have some really good value multimeters.
Some people spend a fortune on the likes of a Fluke meter when it's not necessary. If you are an electrician or into electronics where 99.99% accuracy is vital, then you'd consider a Fluke. But for car electrics, Jaycar meters are more than capable. I still have my $100 Dick Smith multimeter that I purchased back when I started my apprenticeship in 1989. It's one of my most frequently used tools and it's still working perfect.
Drawnnite
Obviously Unsensible
2000 Vs Ute
ill second that. I have a fluke one for work (paid a slab for it =P) and it is damn accurate.
but it wont have all the bits and pieces on it for working on the car.
Jaycar have some good stuff. Definately a good option to go there.
the only upside to say a top of the range fluke is it can pick up rapid changes, such as for oxy sensor voltages. Not many digital meters can read such changes to such small time frame. Or they can bit wont show it.
anyway goodluck
