Hehe, brave answer Abba_Fan hehe. That could really blow the powder keg with an answer like that, but yes i agree, start number isnt too critical, unless its a 0 weight. Dont use less than a 50 in the end figure. If its new, up until 100,000 you can use a 10W50, but even then, slightly higher may be better. 15W50 is a good balance. If you have a VZ or a VE then you can use the lower stuff for the time being, as i myself dont know much about those motors and what they are designed to. BUt with the VT and VX, there is a discrepency, for the same motor, Holden recommended 20W50 then for the VX recommended 10W30, which clearly shows a recommendation to suit Emissions and EPA guidelines. How can you specify 2 different oils for the same motor ??? THen even places like repco will tell you 10W30 too thin, even Holden SPare parts !!!
Seriously, on oils, most are good, as long as they meet API requirements. Theres alot of confusion around oils, and i myself are trying to figure it out. Good oils out there that i would personally recommend and some i have used are;
BP Visco 5000 ($50) - 5W40- Probably too thin, but has always done very well in test, only bad reviews are its viscosity. Available only in 4 litre and 1 litre bottles at BP servos. Again, marketed as a full synthetic, but really only a group 3 mineral, had good levels of ZDDP(advertised).
Fuchs Titan GT 15-40 ($30) - Semi Synthetic, fantastic oil, probably thinnest you would go.
Valvoline Durablend 15W50 ($34-36)- Semi Synthetic, Is more synthetic than Castrol Edge and even Valvoline Synpwoer which others which claim to be full synthetics, when they are only highly refined minerals. Valvoline Durablend actually has 33% POA Lab made real synthetic blended into a Group 2 mineral oil. Valvoline recommend 5000 k changes on all oils. Feels quite thin for the oil it is, did well in a Streetcommodore Test, for oil film strength.
Gulf Western Protecta Ultra 15W50- ($27)- Cheaper option than the durablend, carrying 30% POA real synthetic, blended into mineral oil.
Pennzoil GT Street Machine 20W50- ($38)- Not cheap for a full mineral( made in the USA), marketed more for cars on the drag strip, carries good detergents and anti wear products for components typically found in muscle cars (large cams, solid lifters, etc). Can be used on any car, and is a very good oil. Apparently good for keeping noisy lifters quiet.
ULX-110- ($60-$70) - Full Mineral, U.S designed, not much is known about it except for where its really used, and thats the professional drag strips, circuits etc, probably one of the best oils known to man, but has not been tried by the general public much, Subaru WRX STI drivers swear by the stuff, a non biased soarer driver did extensive tests on it and other oils, and it slightly out performed Mobil 1 Full Synthetic. Easily found info on the net about the test. Performance probably based on high levels on Zinc, and Molybdenum disulphide. Can last up to 15,000 changes if tested.
PM Lubricants Endurance Lube 25W-60($55)- Again a fantastic oil, can be marketed as a full synthetic as it is a Group 3 Hydrcracked oil, designed to outlast any oil, expensive initially, but provides testing, and can on my own car from a recent test can possibly last up to 60,000k's on 1 full fill with filter changes every 10,000 ! Thats means i will only need to pay $55 + 3 filters for a year and a half, as i do about 40,000k's a year. Reported to have the oil with the highest film strength (large market with Farming and construction plant) and resistance to break down, anti wear, looks and even smells good(hehe its like strawberry syrup).
These are my picks and opinions from reading, talking to people, seeing some tests and others opinions, and that is all. Some people dont like Valvoline or Penzzoil, but i feel that is only because they are so common, main 2 oils used in the U.S, been around for ages, and release info about their oils and are easily scrutinised, unlike some other oils. Yes pennzoil did have problems but we talking way way back. I wanna see someone prove it has done something recently to their car with real evidence. If you go no the bob is the oil guy site, Pennzoil, and Valvoline are pretty much the oils to use. They love the stuff. Some people say Valvoline has hardly no additives, which is i am led to believe is crap. Both these oils have done well in oil analysis test.
One oil i didnt really like was Penrite Gas 10W-50- Seems to break down, and didn't really seem to be cushioning the engine as well as the others. I might try it again to see as i may be wrong.
