Which Sway bars
joesvs
41
97 VS Wagon
it's ok. i know the bar... wasn't sure if it was the same one though.
thank you
proto_vr
VR-S Manual
whats involved in adjusting it once fitted?
Michelson4301
41
Cairns, Australia
VS Super6 Utility 5 speed
Simply undoing one bolt each side of the bar and pushing it through the next hole on the swaybar.
VS CALAIS
M6 VF SSV
MELBOURNE
VF SSV 6spd Manual
how easy are they to adjust ? can do by hand or you need tools ?
just asking cause my current car is all stock and looking in to adjustable sway bar...
Michelson4301
41
Cairns, Australia
You can see the bolt in the pic, not a quick release pin, will need two spanners and a couple of minutes to perform. This is heaps easier than replacing the whole swaybar.
proto_vr
VR-S Manual
allright then, its is a consideration, but if i was to just geta solid bar, what sizes would you recomend? 27 or 30? stock is only 26 right? and what about rear what is the stock for the rear
Michelson4301
41
Cairns, Australia
I will tell you the same thing I was told when I asked my local suspension specialist, He said that he would'nt make my mind up and would not recommend anything in the way of one single sized bar, go for the blade cause you get the adjustment for an extra $60, or buy the big bar and be disappointed when it's not what you had imagined.
MBS206
I spoke to a guy who does all of my wheel alignments, and even sets cars up for track work etc.
He told me not to TOUCH the sways bars,until springs and shocks abnd bushes are all done.
The reason being, swaybar should be a final tuning point.
To get more point in at the front, you fit a rear sway bar, so now ask, HOW does it cause more point at the front? It stops the rear wheels gripping up properly (As the camber won't change when shoved into a corner) hence the REAR actually drops grip.
I then went to another shop for another opinion, they said EXACTLY the same thing, and NEITHER of these shops actually sell any springs/shocks.
So I'd do springs/shocks first.
Immortality
Staff member
Sth Auck, NZ
do the bushes first, then, fitting new springs and shocks will already help with body roll. swaybars do effect theway your car handles and i've been told that you need to updrade together, not sure how the rear swaybar effects IRS but probably a little different to the trailing arm setup. however really stiffening one end of the car and doing nothing to the other gonna effect the balance of the car, possibly in a bad way. there is a reason the V8 supercar guys have adjustable front/rear swaybars and they adjust them to suit weight(fuel), types of corners, weather, condition of tyres etc. which modelVR you got, the calais version always was considered to be like a couch on wheels
proto_vr
VR-S Manual
I have a VR S pack
MM, Well what would you guys surgest as far as springs and shocks, (please don't bother saying kings)
I'm still not 100% convinced that i shouldn't do sways first
