whine with acceleration??
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
hey all! this problem dosent bother me but i am keen to figure out why its happening, and how to fix it when/if i get sick of it
ive recently done a full car audio install
heres the list:
sony head unit (250 watt)
jvc 6" speakers (front)
pioneer 6x9's (rear)
sony xplode 12"sub (boot)
2x 600watt amps (1450 watts inc the head unit)
1 farad capacator
and a distrabution block to spread the power arround
THE PROBLEM:
when i press the accelerator the system whines, its like a wistle and it increces as the revs come up, when the sounds are up loud you cant hear it but when there on low volume you can.
i was wondering whats causing this? how do i fix it?
cheers
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
most people will say sound suppressor, but I still say your alternator, I bet if you change it you will notice all your problems going away, the voltage regulator on them craps out and starts giving you funny problems before the bat light on the dash stays on.
Does the bat light on the dash ever come on?
Also generally earth problems can cause whining in stereo gear
HoldrodeoLT
I have no lemon pledge...
2004 Holden Rodeo RA LT, 2008 Polaris Hawkeye 300
heres the list:
1 farad capacator
THE PROBLEM:
cheers
Doesnt this normally happen when the RCA cables are to close to the power line??
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
nope, only when i turn the key to acc
i installed a volt meter last night, it sits at 14volts when the car is running
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
not sure, the rca's and power cable run down seprate sids of the car, or do you mean the head unit power cable?
holdenboy
Custom Car Stereo Systems
40
Nelson Bay NSW
VR Wagon
Where have you earthed off the amplifiers, and did you srcap/sand back the area to bare metal?
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
the amps are earthed on the roof of the boot, kind of inbetween and slightly behing the amps, both are arthd to one point, and yup i sanded back to bare metal
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
i would suggest starting by moving the earth to the floor of the boot, worth a try, the parcel tray should be fine but try the floor cheap and easy to try
ari666
250,000 hits
Timmos
Kellyville
forums.justcommodores.com.au
10' VE SSV
"Engine whine" can be cause by lots of things.
Faulty or cheap RCA's - Go get some shielded RCA cables. They're a bit more expensive but worth it in my opinion.
Faulty Amp - This is only something you can check if you have or know somebody with a spare amp.
Poor grounding - possibly upgrade the power and earth cable size, start by moving the ground cable to a different (more solid) location. Make sure to remove any paint around the ground bolt.
Crossing RCA's and Power cables will cause noise
Some headunits produce a small amount of whine, try grabbing a bit of speaker wire and touch the chassis of the HU and ground it.
Short in speaker wire - Do you notice the noise being in 1 speaker noticably louder than others, or does 1 speaker occasionally cut out? good chance there's a short. Try disconnecting each speaker from the amp 1 by 1. (personal experience i found both my backdoor speakers were causing noise in my system)
