Whining Noise
Brenah
Manly, NSW
VZ Exec Wagon
Hay guys today when i started my VZ there was a weird whining noise. When i rev it whines more. It kinda sounds a bit like a Supercharger whine. (i wish was in ther:surprise:)
Its was to wet and dark to look under the bonnet tonight, i'll do that 2moz.
But b4 i get into it does anyone have any suggestions what it might be. Alternator, water pump, steering???
Ow its a v6 alloytech if that helps.
Brendan S
Appoligies if there has been a thread already done for this
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Could simply be an idler pulley..
jr689
NSW
2003 VYII S 3.8L M5
I'd say it's the alternator mate, my alternator is pretty noticeable in my opinion and it's only done about 5,000k's :s I changed it over after my other one was faulty...
muneey
VZ
had the exact same problem and was driving me nuts after a while..yeah it sounds like a supercharger..mechanic said it was the power steering pump, changed that..problem was still there..found out it was the idler pulley..the one right down the bottom next to the crank
i changed the bearings not the pulley..cost me $12, problem solved
Jonno
Vic,
dads 07/08 colorado has that, been like that scince actory though so havnt done anything about it
Brenah
Manly, NSW
VZ Exec Wagon
Yep found it. It was the idler pulley bearing. Sprayed wd-40 to see if it was a bearing and the noise stopped when i sprayed. So i'll change that on the weekend. What size is the bearing?
Cheers guys.
wattles
Mt Isa
Vz Sv6 04
i got the same problem, where did you get the bearings to change?
richardpalinkas
Blown Alloytec
Gold Coast
Raptor Impulse VZ SV6
you should never spray wd40 on bearings. my dad (mechanic) told me that. something to do with because they should be greased, and when oil is added it gets rid of the grease. id just replace it. whether this information is correct, i dont know, im not a mechanic...
