Who has a VP with ABS? Need overflow/washer bottle part no.
dans_vz
Swan Hill
MY16 VFII SSV Redline Manual & MY13 VDJ76 Cruiser
Hi everyone who has a VP that has ABS?
I need to check the part number for the coolant overflow/washer bottle as they are different part numbers it seems from the other ones (as the abs module fouls the older model ones)
hi_ryder
Donating Member
Pascoe Vale South, MEL
far as i know the vp only uses the one overflow reservoir for all models, v8, and v6 both abs and non abs. if you can find one with a different part number than 92043144 post it up... if the one you have isnt fitting it might be off a vn (the one just after they change from the self bleeding system).
dans_vz
Swan Hill
Yes, the one I have isnt fitting properly, I beleive it to be a VL/VN one then since it isnt the number you have listed above.
Thanks hi_ryder
If anyone else has a different numbered one in a VP, I would be interested to know. Just want to chase up the right one since they are $80ish.
hi_ryder
Donating Member
(standing in front of the shock tower, facing the open engine bay) if the cap on the windscreen washer bottle is at 10 o'clock than its a vn unit. if the cap is at the top towards the firewall at 12 o'clock than its vp.
dans_vz
Swan Hill
Interesting, I never knew this or realised it, thanks
dans_vz
Swan Hill
And yes, I realised the one I currently have is the VN unit
