Ok the other day i sent this e-mail to Intense racing.
''Hi,
Im building my L36 twinturbo.
Im running your L32 rods and your coated Diamond Racing pistons 8.0:1.
On assembly im finding the small ends of the rods are slightly out of centre on the wrist pin. This causes the small end of the rod to slightly rub one side of the radius inside the piston.
I don’t quite understand when you say bearing tang toward the pan rail as there are 2 sides to the pan rail.
I have installed them with the bigger chamfers of the big end towards the nearest main bearing. Is this right?''
I got this response.
''There should be no contact of the piston to the rod. The rods all have a dot on the beam above the bearing on one side. That dot needs to be facing the front (pulley side) of the engine on all 6 rods. Also make sure the pistons are all facing the right way, they each have the letter “F” stamped on them. The “F” should face the Front of the engine as well.''
I then sent this back.
''Thanks for the reply Chris.
Why does it say ‘’Bearing tangs toward pan rail’’ at the bottom of the page?
INTENSE-Racing.com: L32 Connecting Rod
If that is the case then you will have half the dots facing forwards and half rearwards.
I just wish I could get a straight answer from someone lol. I can’t find a definite answer anywhere.''
I got this response today.
''I have no idea why the website says that, or what it really means. It said that before I worked here, I am going to see if John will change it. Anyway, the dots definitely point towards the front.''
I think im going to go dots face towards front lol.
