why dosnt my fuel light come on when its empty??
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by MTX_15inX2, Sep 20, 2005.
  1. MTX_15inX2
    MTX_15inX2 Guest
    hey i have a 93 Vr executive and when the fuel runs down to like empty the light dosnt come on and i was just woundering why
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    mine doesnt either.....i figured that it was just because my car is lowered and because my car can still run when the needle is below empty :yeah: doesnt get like it too often though...
    it comes on when it is just under the empty
  3. Fekason
    Fekason Fekason
    Penrith NSW
    Could just be the bulb!
    It might be just a blown bulb. I have had to replace a couple of the warning/caution light bulbs.
    I don't have my manual with me, but I think there is a way to check that the light is functioning during startup.
  4. Infus10n
    Infus10n New Member
    Holden Captiva (Work Demo)
    the globe could be dead?
  5. Charg'd
    Charg'd New Member
    in a ford
    ford
    any one nos how to change them?
  6. Infus10n
    Infus10n New Member
    pull out your cluster and on the back are several light globes which twist out...
    that simple.
  7. Charg'd
    Charg'd New Member
    in a ford
    ford
    are they a special globe?
  8. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    Not totally sure but my car when it had a L2 dash fitted didnt have any lamp when that lit when the fuel got near empty even though there was a idiot light symbol on the dash for it but it did have a low series bcm and it is a vr exect.The speed alert makes a beeping noise if you have one fitted .
    My car now has a L3 dash so it has all the bells and whistles
  9. Fekason
    Fekason Fekason
    Penrith NSW
    VS Facts
    Hi again,
    The VR and VS had the same cluster. My VS S2 Level 2 cluster had a fuel low light that worked.
    The warning lights are all the same type. However, they are not standard "bayonet" type bulbs.
  10. Infus10n
    Infus10n New Member
    they are 20mm wedge globes if i remember correcly. Just goto autobarn and ask for some wedge globes for your cluster, they will know the ones.
  11. Charg'd
    Charg'd New Member
    in a ford
    ford
    thanx mate
  12. garfa
    garfa New Member
    SE Victoria
    VY SS
    nah the bulbs for the indicators and such (inc empty light) are not normal wedge base! i am pretty sure of this. the are a tiny wedge bulb but the contacts are little pieces of wire which are soldered to the bases contacts. you need to buy a whole new base and bulb. its a 1 piece unit. the bulbs for the speedo are the 20mm wedge.
  13. kopper69
    kopper69 New Member
    VRII Acclaim
    They are a wedge base about 20mm all glass. Mines never come on and i would never want to try it. Letting your car run till empty is a perfect way to make all the impurities clog up the filter and reduce your fuel efficiency. Just dont let her run dry.
  14. fixxxer
    fixxxer Member
    VF SV6
    B4 u go assuming its just a globe, does your fuel alert make a beeping noise?
    Mine makes the noise then the light comes on, if your getting the noise but not the light, then yes id say it a globe, however if your not getting the noise or the light, it could be the fuel sensor in your tank or something
  15. Charg'd
    Charg'd New Member
    in a ford
    ford
    i dont have the alerts series 1 vr exec
  16. haha
    i was thinking the same thing, everyone is jumping on the globe bandwagon, in my car the globe is fine but the speed alert just stopped working one day, i found out when my car ran dry, i thought i was fine cause the light hadnt come on, i have a speed alert and it doesnt work either, i dunno why it stopped probably a repocussion of pulling my car apart and putting it back together to many times haha
