Why is my car 15mm higher on one side?
S2_VR_
Northern Rivers, NSW.
03' M6 VY SS ute
hey guy's, i just lwered my car on pedders (only the front atm) but the driver's side sit's nice and low just above the wheel,
but the passenger side sit's like 10-20mm higher than the other side ????
wat's the go?
i'll try get some pictures up soon....any ideas?
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
did YOU just lower them or get a suspension place to do it?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
did you look at the springs to see if one had drivers side written on it
S2_VR_
03' M6 VY SS ute
i did it, (like many times before on previous vehicles)
and yes they were marked "Left" and "Right", the spring is sitting in it's correct housing too, any other ideas?
Adriianz
GTS
umzzz correct me if im wrong, but cant you adjust panhard rod to make the car even?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
what were the strut tops like where the shocks bolt to the towers not got one flogged out one.panhard rod only centres the diff in the middle of the car
(CODEZ)
formerly cody_vp92
western burbs, SA
VP v6
is the spring sitting in the correct place, my mate has a vt with the same thing and he said that his spring popped out when he went over the train lines heaps fast, dont know if that happens though?
centy
Vp series 2
A hell of a lot of cars sit like that.
Mainly because the spring makers make them to keep the car level.
The roads aren't flat they slope.
social
Ute Finatic
South Aus
2012 VE Thunder
hit a kerb or something lately? You may have bent the shocker, this can cause it to take alot longer to retract causing the car to sit higher up.
