Why is my VE 3.6 Alloytech quicker than my VZ 3.6 Alloytech?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Emono5, Jul 1, 2011.
  1. Emono5
    Emono5 New Member
    VZ wagon
    Same engine, heavier car....why does the VE feel so much more responsive?
  2. undersuspicion
    undersuspicion Now That's How We Roll!
    Vy SV8 Series 2
    more research into the ve's engine im guessing.
  3. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    the ve has 210kw's(i believe) and the vz has either 175 or 190kw.. depending on model. so its just further development have made them a bit quicker
  4. duehicky
    duehicky New Member
    brisbane
    VE SV6 Sedan
    Isn't the alloytech 195kw cos the sidi is 210kw
  5. Cameron P
    Quakers Hill, NSW
    REDHOT VX SS
    i new the sidi's were 210... not sure about the earlier ve alloytech's.
    my point was the ve's have more power then vz's cause of development...
  6. Fekason
    Fekason Fekason
    Penrith NSW
    Power Change
    I believe that the VZ Alloytech put out 190KW in the SV6, whereas the VE Alloytech was 195KW pre the SIDI.
    However, the biggest difference appears to be torque delivery. Both engines had the same 340 NM, but the VE figure was at 2,600 rpm versus 3,200 in the VZ, i.e. higher torque at lower rpm for the VE.
  7. Emono5
    Emono5 New Member
    VZ wagon
    Redbook
    Redbook
    The VZ has 175KW @6000RPM and 320Nm @ 2400RPM
    The VE has 175KW @6500RPM and 325Nm @ 2800RPM
    so they are very similar statistically, but the VE feels like it has heaps more go than the VZ, despite it being 145KG heavier.
  8. brad VE SSV
    brad VE SSV New Member
    NSW
    2011 VE SSV redline wagon
    No actually it's series 1 Vz is 175kw and series 2 Vz is 190kw.. I know because I have one..
  9. LachieSV6
    LachieSV6 New Member
    Eastern Suburbs
    VE Poison Ivy SII SV6
    those specs are wrong!
    VEs are either
    2006 - 2009 Late:
    195kw
    2009 to present:
    210kw SIDI
  10. TrikkBen
    TrikkBen I'm Back :D
    SE, Vic
    BNR32
    Just buy a V8 and it will be faster than both. <--- Someone had to do it :D
  11. azzss
    azzss New Member
    Bushfield, Vic
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    VZ V6 '04/'05 models excutive,acclaim and berlina 175kw. '06 172kw=loss of 3kw because of emissions regs i think. I carn't remember about SV6 and Calais (190kw) engine if it changed power figures. We have a 04 VZ acclaim and a 08 VE lumina in the family, and the VE fells alot more responsive than the VZ alot more than the claimed 10kw or so difference (VE 185kw i think?).
    Cheers.
  12. torana355
    torana355 Member
    VE SERIES 2 MY11 SSV A6 in IVY GREEN
    Different gearing mate.
  13. kuzman89
    kuzman89 Active Member
    vic
    VE SV6 ute
    The torque/power curves are marginally improved in the 195kw, transmisson and the gearbox are also better and the car gets better traction off the line with IRS and a decent suspension. It also has slightly better diff gears 2.83 vs 2.93? (not sure if thats exact), theres some other differences to do with cam phasing etc
  14. Hym1e
    Hym1e New Member
    2007 VE SV6
    I thought the omega were only 180kw... So whats the difference with the high output badge on my sv6? I know mine is 195kw apart form the obvious :hit:
  15. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    Are they both high output/low output engines and do they have the same gearbox? A 4 speed VZ with single Variable cam phasing would get smashed by a 5 speed VE with intake and exhaust variable cams regardless of the extra weight
