wierd noise PLEASE HELP!!!!!!!!!!
fatbt1
vn bt-1
hey all i have a vn v6 bt-1 ex cop car it has a chip,computer,custom exhaust,k&n racing pod filter and recently i shaved the lil butterfly flap down in the throttle boddy about half a mm my problem is yesterday to prove my point and hava laugh i raced a diatsu charade and ford lazer (please dont ask silly i know) after whipping them both sideways twice with whel spin i decided i had enough so i parked it its then i relised a noise coming from my head (sounds like tappets but i could be wrong) i topped up the oil and added engine and tapped tune up cleaner it has softened the knocking noise a little but its still there when i drive it isnt really bad but when the stock auto box tried to change gears(its worn to the **** house and slips if i punch it hard) i can hear the noise clearly i had a look at it and made sure all oils were topped up my gearbox has a leak some where but the noise sounds like its coming from the head like tapped slap or something any help would be muchly appreciated this is my 3rd vn i dropped the bottom bearing in my first (no oil) and my second was ripped off and burnt 1 day after fitting big $$$ worth of mods i dont want to send this to the grave yet but i also dont wanna fork out 2grand to have a pecker head have a look at it thanks in advance
sircruisealotVS
39
South Brisbane
VZ LS1 Calais
Did they teach you anything about full stops, spaces, and capital letters in English lessons?
lmao...yeah, its a bit hard to understand all that huh.
but as for the problem...if i understood correctly what was being said, i think the noise may be from the lifters sticking. they cause a sound like you discribed fatbt1. the fact that the noise quitened with an oil top up further convinces me its something along those lines.
mag 87
newcastle
series 2 vt wagon
take your rocker covers off and have a look closely and if your starting to get a grunge build up around your valve stems spray a bit of wd on em and that might help the **** fall off... just remember to clean it up so it doesnt go down to the galleries and clog them up!
