Will 17'' or 16'' rims fit on a VE SS Ute
KustomKulture62
Queensland
2013 Specialized Hardrock Sports Disc 29er
Wonder does anyone know if the VE ss utes will take smaller rims.
Maybe 17'' or 16'' its just that we live in the outback and would like the extra sidewall thickness.
stick3
newcastle nsw
vz sedan vs ute gsx1400
only way you make them fit is to down size the front v6 rotor,caliper mounting brackets v6/v8 calipers are the same
KustomKulture62
Queensland
Thanks stick, looks like we'll be staying with the 18'', maybe Pedders could fit some you beaut shocks and springs to handle the bad roads a tad better.
lowandslow
NSW
V2 III Monaro
The standard FE2 stuff should be as good if not better than the equivalent from Pedders. Springs especially.
lowandslow
NSW
V2 III Monaro
They're swaybars and link pins?
VS_Pete
Donating Member
