will 225/45ZR20 pentagons fit on my Vr sedan?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Sando2709, Jun 13, 2019.
Tags:
  1. Sando2709
    Sando2709 New Member
    vic
    VR COMMODORE EXC BT1 V6 FE2
    its got FE2 springs and im worried about the guards if they need rolling, if i need different springs and if they will rub and stop me from turning properly.
  2. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    What size tyres you have now ?
  3. Sando2709
    vic
    205/65r15, stockies
  4. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    No rubbing with stockies. all good to go.
  5. Sando2709
    vic
    I know the stickies fit but I want to know if the 225/45ZR20 will fit properly
  6. EYY
    EYY Well-Known Member
    VS Statesman
    You need 245 30 20. The tyres you have will rub on wheel arches at rear and hit struts at the front - you won’t even be able to bolt them up
  7. Sando2709
    vic
    Will 225/35ZR20’s fit?
  8. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 6 speed Auto Wagon
    Profile is wrong.
    20 inch rim tyre profile is 30.
    19 inch rim tyre profile is 35.
    18 inch rim tyre profile is 45.
  9. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Profile is a ratio of width, so goes up as width gets wider.
    The height is the issue on the front. I know 25.7" height fits (245/45-17).
    OP, that is like a 28" tyre. You have no hope
  10. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    There's no right or wrong profile for a particular wheel size. Think about all the Commodore owners running later model 18s that can't use 45 profile tyres because of scrubbing on the spring seat.
    OP, use this to compare - www.willtheyfit.com
    VS 5.0 likes this.
  11. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Using that link, OP will need 225/30-20 tyres to make it work
  12. VS 5.0
    And the sidewall would be 18.25mm less than on my 245/35/20.
    Not something I'd want to be running.
  13. Deuce
    Deuce Super Stock
    '94 VR SS V8
    Me either.
    I reckon 18's MAX on a 2nd gen. I have 17s which are nice.
    VS 5.0 likes this.
  14. VS 5.0
    Indeed.
    The VE with 20s rides better than the VS with 18s.
  15. EYY
    VS Statesman
    My vx with 18’s handles and drives so much better than my vs on 17’s. So much more relaxing to drive the vx.
    Never thought it was that bad until I spend a while in the vx lol.
    VS 5.0 likes this.
  16. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Yeah blokes that fly past me at 110 on the highway corners, with me feeling safer at 90 than the 100kph limit are often driving VE utes. Like EYY i thought the ute handled reasonably well.
