will a ford t5 bolt up to my vn v6 bell housing ??
Coatesy666
VN 5L CALAIS
just wondering if a t5 out of a ford eg. ea eb ed will bolt straight up to a vn ?
need to know asap thanks
FusionX
Western Aus.
While yes it will bolt up to the bellhousing, you will have issues with the input shaft.
The input shaft on the Ford T5 is a different thickness and won't fit the Holden clutch plate (I found out the hard way, about 1/8 an inch difference). Chances are the input shaft is also a different length as well.
cander24
NSW South Coast
VZ GTO. VS LS1.
Thats correct :thumbsup: The ford T5's ran a different input shaft. If you can source an input shaft from a holden v8 (or a v6 and have it shortened) you should be able to swap it over, but they're pretty hard to come by these days without buying a complete box and the new repro input shafts are well over $500 from memory.
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Ford T5 to Holden bell = Ok
Ford Bell to Holden block = Fail
Ford T5 input to Holden motor = Fail
Overall Ford T5 to Holden = Fail
Reaper
