Will a high flow cat make a difference?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by someguy360, Jun 11, 2011.
  1. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Hi Guys
    Just had my new exhaust system installed Pacemakers through to a 2.5" single high flow muffler system and it sounds great.
    Just wondering if it would be worth replacing the stock cat converter with something like this
    SS304 2.5" High Flow Metal Cat/Catalytic Converter 100C | eBay
    Would be nice to make the exhaust a little louder than it currently is and would help with flow/power a little?
    Just wondering if I will get any power/sound gains by doing this
    Thanks
  2. RIDE:42
    RIDE:42 crew chief
    vuss
    If you are going to run a cat put one on thats legal that is a pre cat Cheap way out put one on that is off a manual v8 (auto ones 2.25 m6 2.5)
  3. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    100CPI is illegal due to emissions. 200CPI is legal. Sus out ballistic racing their cats are top notch. 8's and 6's have the same cats. You think Holden would bother spending the money on two different ones (talking VS here)
  4. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    If your cat has never been changed there should be a gain/restore in power as it will be blocked with built up carbon deposits, cats are meant to be replaced at around 50,000Km's supposedly.
  5. Crazy_C
    Crazy_C New Member
    Kent, UK
    VS Wagon
    My VS 3.8 Ecotec has no cat in it, and it is glorious to drive, but it's an import here so the regulations are a bit more lenient.
  6. QldKev
    QldKev Member
    Qld, Australia
    VX Berlina - GENIII
    I'm not 100% sure of the info for a VS V6; but I can tell you for a LS1 setup which I assume would be the same.
    The stock one has 400 cells per square inch. Both 200 and 100 are illegal. From my research a 100 cpsi will fail an emission test; but generally 200cpsi will often come in close on the limit. Also 100cpsi you will smell fumes from it, and I know a few guys who have swapped them out for 200cpsi.
    On the LS1, a big restriction is not necessary the cat, it is the pipe heading into it. It is only 2.25inch but has a really bad crush bend in front of it; making it as good as a 2inch pipe, the VS may be the same.
    The less CPSI the better the cat will flow. By changing you will get more hp and a louder sound. Don't expect to find a lot of power thou, unless your current cat is blocked up the ****.
    QldKev
    QldKev
  7. tosue
    tosue New Member
    rosebud,vic. mornington peninsula
    commodore vt executive wagon "98"
    piss on the bck wheel
  8. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Only some 200 CPSI cats are legal, not all of them. I do the MagnaFlow steel 200CPSI cat, and it is legal. It is one of the few that come in under the EPA emissions limit.
