will a VN T5 fit straight into a VS
TazzieTLR
Launceston Tasmania
vs ute
i can get a complete T5 removed from a vn
will this fit into my VS ?
if not what is needed to get the job done?
thanks a million guys
Pub247
Melbourne S.E.
Ford Fairmont
most of it will fit what you'll need for your VS is a VS manual wiring loom and ecu. You will also need an VS T5 Ecotec Flywheel. You'll find these 2 are the hardest parts to find and the most expensive
TazzieTLR
Launceston Tasmania
vs ute
most of it will fit what you'll need for your VS is a VS manual wiring loom and ecu. You will also need an VS T% Ecotec Flywheel. You'll find these 2 are the hardest parts to find and the most expensive
my vs is already a manual but it has a getrag ??
Pub247
Melbourne S.E.
Ford Fairmont
If its a getrag i suggest you stick with it unless its broken. Some people have a preference to either one but i dont think there a lot of difference in some ways a getrag would be better for the hydrualic clutch.
Being a manual already you wont need wiring loom or ecu (at least i assume theyd be the same whether its a t5 vs or getrag) So you'll need to find a t5 flywheel as getrags use a different one. You'd also need to change tailshaft yoke pedal box and remove the clutch Master cylinder. You need to change gearbox mount i assume and will need the manual short loom that connect to the reverse light and speed sensor wiring.
It may be more trouble than its worth and i might have missed a few things along the way someone may help clarify some points about the conversion
TazzieTLR
Launceston Tasmania
vs ute
ok this has all changed, seeing as my engine is a supercharged v6 it would actually be a series 2 vs - vx ecotech. are these different again to the earlier ones
can a vn manual box bolt up to say a vt ?
im learning know i would need a different flywheel and clutch conversion, just wondering about the actual bolt hole pattern on the bellhousing. cheers
