will a vr compressor for air conditioning fit a vs?
jamiebrown
townsville
1996 VS acclaim
just a quick question because i have a vs and an old vr which i use for parts, although they look the same very different mechanically. my air con runs at about 12 degrees after 15 minutes or so and should be about 7 degrees pretty quick, i was told it was the compressor and was quoted $660 for the part. air con was re gassed and tested for leaks so it isnt either of them.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
I'm no expert on aircons, but from experience it would be difficult for the aircon bloke to blame the compressor for not dropping the temp down to 7deg - there are many other variables that can also cause poor cooling which are a lot less drastic than a new compressor, like tx valve buggered/dirty, condenser blocked etc.
The VR comp should be identical to the VS one - visually check them....however I would not use the VR one if the aircon in the VR has not been working as moisture gets inside them pretty quick when they have no gas.
A final thought and one which may save you some cash - it's very common for some aircon blokes to quote for repairs that are really not required - and from your description, and I'm only guessing that it may apply.
What happens is that the hot/cold temp dial on the console connects to a vacuum switch that turns the hot coolant flow on for when you dial HOT and off when you dial COLD. What happens is the dial operates a metal rod that connects to a flimsy piece of plastic, and over time the rod slips off the plastic so that when you dial COLD it fails to turn the heater off and your aircon then is supplying COLD and HOT air at the same time which results in warm air....exactly what you are getting.
To check if this is so, check that the brass heater pipes are cold when the temp dial is set to cold and the engine is running - they are located just to the left of the drivers ankle and up a bit - see attached pix. If they are warm/hot, then that is your problem. Simply reattach the rod so it depressed the black knob.
I lived for 15 years in Townsville and I know of quite a few blokes who've been told that they must spend a lot of $$$$ when the fix is as simple as refitting the control rod. I had a aircon bloke then who was really good and honest but unfortunately he has since left so I cannot recommend a good one, but be careful.
Good Luck.
wamboin23
Donating Member w/ Boost
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VR Acclaim V6
pretty much the same. only difference is the top front mounting point. it is about 15mm too long to fit. easier to just get something that is right.
Julzz
51
st johns park
vs commodore
Good Luck.
Hey my rod is connected. But go back to where you said, "check that the brass heater pipes are cold when the temp dial is set to cold and the engine is running.............. my brass rods are still hot. I have a brand new a/c fitted in my commodore and it blows hot air, i taken it back to mechanic but his dumb founded, so now i'm stuck. any other options you can think of???
CCCMikey
Black Mountain NSW
VS '95. LPG. 513,000KM
Is the heater tap in the engine bay working I wonder? It's vacuum driven.
CCCMikey
Black Mountain NSW
I'm not sure to be honest, never checked mine. I guess disconnect the vacuum line and see if hot water still gets through. But I don't know if applying a vacuum turns the tap off or on. Either way I'd assume that when the selector is on full cold, there shouldn't be hot water flowing through.
Julzz
51
st johns park
vs commodore
I took the car back to the mechanic today for the second time since it's still under warranty, it cost me $1800 for the whole setup, a/c compressor, condensor, pipes, lines, taps etc so i expect results
