Car Audio Factory Outlet
- Dec 1, 2006
- 450
- 3
- 0
- Location
- KENMORE QUEENSLAND
- Website
- www.caraudiofactoryoutlet.com.au
- VK BROCK Group "A"
id rather just make the box smaller.. the reason i made it that was cause i made it to the dimentions that would fit perfectly into the back of the vn, then id put the flat board across it ill post a pic of my sketch
Make the box the size you want and then add some expand-a-foam the high density one and trim out to suit!
you can use the bean method of measuring you box volume --- that is get a bag a bean bag beans and fill you box with them and then take them out using a bucket of a known volume that will give you the litres that it needs to be then you can add and subtract foam as needed
That is the easiest way
Will get back to you with some specs
