Will This Diff Fit
jezz736
Cooranbong
VE Z Series Commodore
bigdaddycool
Brisbane, Queensland
2009 VE SS SILVER SEDAN
Yeh I bought one off the same mob............... had it about hmm a year now. Damn good, well worth the money. I fitted mine...... took bout 12 hours, alot of work. The LSD's are very tight for the first week or two when u first put it in......... then they wear in a bit and settle down but definately a good upgrade to any VZ.
Just gotta recalibrate your ECU for the new diff........... which is the biggest pain mostly as u gotta readjust your WOT shifts mostly...... eg. standard VZ can run upto around 72km in first gear, on these diffs at about 6400rpm (if u raise the limiter) they will only get to 66km/h in a 4 speed auto.
Hope that helps. Cheers
jezz736
Cooranbong
Cheers mate, i was hoping to hear something like that :)
This may be a stupid question but do u still need to recalibrate the ECU with a manual? or is it just bolt in, job done?
Jayrock
Foxton
Vx ss 3.8l v6
Well a 2004 sv6 diff fit into a vx ss 3.8l
krusing
Melbourne, Bayside
Assuming it’s a VY diff you want to install in the VX ?
And assuming its a different ratio ?,
There is a few factors to think about,
The diff yoke Is different,
And the Dash PPK will need to be corrected, which also depends on the size tyre/wheel combination your running.
losh1971
North Tas
VE Series I SS Ute
If I had an option of ZF or M80 I know what I'd choose. Unfortunately I'm stuck with the ZF......
