if you're just using the engine into the VT where's the issue same engine, right?
oska Active Member Joined Oct 14, 2010 Messages 817 Reaction score 51 Points 28 Location melbourne Members Ride vx custom 600RR Feb 28, 2011 #11 if you're just using the engine into the VT where's the issue same engine, right?
B bogan_vk New Member Joined Aug 10, 2009 Messages 728 Reaction score 4 Points 0 Location australia Members Ride commodore Feb 28, 2011 #12 it will fit but you will just have to swap a couple of parts over from your old motor, i did an engine change a couple of weeks ago putting a vt motor in a vs so if it works the other way around it will work in yours.
H holden91 Kickin it sideways Joined Mar 17, 2010 Messages 33 Reaction score 0 Points 0 Age 32 Location rockhampton queensland Members Ride Vs series 3 ute, ve berlina and a eh wagon Feb 28, 2011 #13 thanks for all the help, watd u have to change?
FstStig Diagnostician Joined Sep 17, 2008 Messages 1,140 Reaction score 12 Points 38 Age 34 Location Central Coast, NSW Members Ride 2010 VE SV6 Feb 28, 2011 #14 thanks for all the help, watd u have to change? Click to expand... You will have to change your inlet manifold over as the VT's have a EGR valve Click to expand... Just this ^^^ Edit: No this can't be done legally. You can't put an older engine into a newer car even if it is the same engine.
B bogan_vk New Member Joined Aug 10, 2009 Messages 728 Reaction score 4 Points 0 Location australia Members Ride commodore Feb 28, 2011 #15 i just changed the inlet manifold and all associated gear on it rest of the engine is the same.
