Will Vp V6 sedan transmission fit wagon Vp V6
Newbie1991
New South Wales
VP Executive V6 3.8,VP Exceutive S2 3.8L 5speed
Hey guys will a Vp v6 sedan transmission fit my Vp V6 wagon like straight swap over thanks in advance guys
losh1971
North Tas
VE Series I SS Ute
Yes, if both are autos. You will need to keep the wagon tail shaft. Assuming you don't have a column auto in the wagon?
Newbie1991
New South Wales
Sweet as mate and there both the exact same except one being a sedan thanks heaps m8 one more thing are you meant to be able to hear your petrol pump running all the time
Jezza95
South Australia
VP v6 IRS executive
Your only suppose to hear the fuel pump turn on with the ignition for a split second, but all though it may be on its way out or struggling to keep the flow.. if it's in a wags then you'll most likely hear the fuel pump running constantly cause it's in a hollow cab, if you get what I'm saying??
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Some fuel pumps keep running for up to 20 secs after turning off the ignition due to the fact that the oil pressure is slowly dropping.
