Will VY rims Fit onto a VE
stick3
newcastle nsw
vz sedan vs ute gsx1400
ve/f studs and lug nuts a bigger/ thicker than earlier models dont know if you can drill them out it may compromise the integrity of the wheel and cause it to crack
MaxiRose
30
Innisfail ,Qld,4860
Ve S1 2009 Sportswagon
will a Vz rims Fit or is it the same as the vy rims ...or dose it have to be ve or vf rims to fit straight on
stick3
newcastle nsw
ve/f are bigger.. vb-vz wheel studs are all the same size thats why it easier to fit wheels from ve/f to earier commys by just removing the lip in the middle and you can get the lug nuts that are especially made for this conversion
mike_nofx
VE SS Sportswagon
Have seen VY rims advertised as fitting VE, but generally come with wheel spacers 8mm or so. I’m guessing wheel offset is different VY to VE also?
Fu Manchu
WA.
Off set is different. A VB-VZ wheel will have many different off sets as it is, yet all fit.
Generally a VY-VZ Wheel will sit noticeably inward of the guard if fitted to a VE.
As mentioned the studs are different and centre.
vc commodore
Like the Leyland Brothers
VC, VH and VY
Yes offset is different with the vE/VF wheel and the reason they sell them with spacers is so you don't have to get the centre machined....Spacers are illegal to fit too
figjam
Donating Member
Far Kurnell
FJ
Without getting specific, most pre-VE are +48 offset, and most VE/VF have a variety of +38 or +43 offset.
