Will VZ SSZ 320mm brakes bolt up to a VZ standardbrake hoses ?
vsl67
VS l67 statesman
Im upgrading my Brakes to the SSZ 320mm disc and C6 calipers soon on a VZ SS and want to know if the standard hose bolt up ? as the mounting points of the hose ends are different and cant seem to find any reference to needing different hoses
vsl67
VS l67 statesman
Bolted the brakes up other than having a caliper bolt strip out there was no other dramas and the brake hoses fit
2Com
$$$ talks Bullshit walks
VZ
YES! YOU CAN use the standard VT-VZ brake hoses with these (I did). They are actually LONGER than the SSZ, Monaro ones. All you need to do to instal them into your new bigger calipers is rotate the end 180 degrees where it screws into the caliper body (1st pic). Works out perfectly. Then, because the standard brake hose is longer, you can pull the excess length back at the mount (2nd pic) on the strut. I'll be happy to assist anyone with more questions.
