Pcal
- Jul 23, 2019
- 5
- 1
- 3
- Location
- Adelaide Hills
- VE Series II Omega LPG
Hi Guys,
A while back someone was being silly in the front seat of the car, and leaned on their elbow right on top of the window switch panel in the centre console. I wasn't there at the time, and those who were are a bit coy about who exactly was responsible...
Anyway, the retaining clips on the front edge of the panel have come undone (the rear ones are still holding it in place - albeit on a bit of an angle), and it has resisted all attempts to find a way to press up from underneath it to clip them back into place. Every time a window is opened or closed, I'm worried there will be a small pop, and the entire switch panel will disappear into the nether regions of the centre console never to be seen again.
I've taken off the side cowling as per a youtube video I found, but the top panel of the console just will not come off. I've had bleeding finger tips from the attempts to remove it, and can't see anywhere I could push up a rod or anything that would have a clear path to the back of the window switch panel.
Is there some trick I've missed about how to get the top panel off, or some other way to approach the problem. If I could only get to it, it seems a simple enough thing to fix in a moment...
Thanks in anticipation
