HDT_aero
Banned
- May 3, 2005
- 1,285
- 11
- 0
- Age
- 38
- Location
- SA
- manual VN aero
Hi guys n gals does anyone have any tips to remove front and rear windscreens without breaking them i have the front and sides of the seals for the front off and im having difficulty getting the bottom off the frame.
now this particular screen only has side and top seals and the bottom is glued (or whatever they use) so is very tight getting a stanley knife in.
the rear screen i have cut through the top and the bottom no problem but after getting half way down the sides the glass goes lower than the pillars making the only way to cut them from the inside and it is prooving quite back breaking and cramping not to mention my stanley knife hardly does any damage to the seal (ive been using a kitchen knife for the rest)
so i thaught before i get too fustrated and break the two screens id see if you all have any tips to make life easier.
the reason they are coming out is cause im painting the car and want to remove the surface rust behind the seals to stop it spreading under my new paint
Thanks
Adam
Thanks
Adam
