Hi anyone with washer bottle problems.
Just had to investigate my VX2 Commodore. The front windscreen ones wouldn't work, but rear OK, so pump working & plenty of water.
So what could it be? Lift bonnet and the washer water hose is hanging off the bonnet, along with a 330 degree (approx) joiner. Easy job, its come off from somewhere, but where? Pulled gently on all the rubber hoses along the firewall and everywhere else - no joy! I had vision that it must have come off and flipped around the drive belt, where obviously it would have a short life!
Eventually found it in the channel on the right hand side, tucked neatly away. Plug it in and away it goes. Refill with water and fluid and all good to go.
Took me far too long to work out the correct location, to plug it in, so I hope this helps someone & gives others a laugh!
