D
deebs
Guest
i have purchased a vn and am having trouble with the wiper arms.
on the down stroke the wiper blades don't touch the screen properly, leaving large deposits of water on the screen.
i have replaced the blades, heads and arms and it stil happens.
i removed the plastic cover to gain access to the wiper motor and tightened the motor and arm assemblies.
it still happened.
then i took note of the plates where the wiper arms were mounted,, there seems to be unacceptable flexing in the plates, which are attached below the windscreen, causing the wiper arms to loose strength in holding the heads on the screen on the down stroke.
is this a common problem and is it repairable?
what can i do as it is a major issue during wet weather.
thanx for any replies.
it still happened.
