wiring an extra check engine light VT series 1
nes138
Gippsland Victoria
FC HOLDEN with 5LT V8 (VT)
Anyone please help, need an extra check engine light wired up for a custom job. I've looked at the aldl wires and even splicing into the instrument cluster wires to no avail.
Much appreciated in advance.
oska
vx custom 600RR
That's pretty simple just solder 2 wires where the globe base makes contact on the cluster, connect the second light where you want
remember both will light
nes138
Gippsland Victoria
Thanks Oska BUT- This would be extra simple if I had the cluster installed.... All the VT wiring is transplanted into a 60 year old car!
So I need to use the wires from somewhere else and that is what I need help on
oska
vx custom 600RR
ok
all the information is carried on the serial data line pin 12 on the cluster, then the MCU in the cluster interprets the signal to turn on the warning lights. even if you were to mount a cluster somewhere you would also need every sensor that was fitted to the engine to operate correctly
so i don't think it would be possible i thought you just wanted to mount a secondary CIL
nes138
Gippsland Victoria
Nah wish i had the original cluster installed but can't even hide it somewhere. I've manage to convert all the other wires into the the cluster except this (and the horn :( )
I think using instrument cluster pins 6 and 12 -ve with 19 and 20 +ve illuminates it but unsure if it will work ok
nes138
Gippsland Victoria
I can also see 5v 'flashing' off the green/white serial data signal wire (when ALDL 5n6 are bridged) but can't get a bulb to flash with it for some reason. Don't know if its just not enough juice, my knowledge here is lacking
Frank A
56
VX Berlina
Trying to do the same thing on my v6 conversion,my PCM doesn't seem to have a green/white serial data pin? Any ideas?
