Connect the Power Side to the BCM (Connector 2, Pin 5 - Dark Blue / White Stripe Wire)
Connect the Ground side to the BCM
(I am not too sure, but I think it is BCM Connector 2, Pin 25 - Purple Wire)
Best you check this one with the multimeter for the moment...
(I will try to check the wiring diagrams tonight if I get a chance)
For more information on the BCM
www.carmodder.com • VE Factory Body Control Module Information
The second connector should be the green connector on the BCM, and the BCM is located above the accelerator pedal, in the drivers footwell.
(You will need to remove the footwell cover, and possibly the large trim piece that holds the headlamp switch.
Hope this helps
