Wiring/Fuse Problem with Head unit
Mzil
30
Brisbane, Queensland
VY S Ute 5spd
Today i was trying to switch over a head unit in my VS. I had all the power wiring cut off from the old harness onto the new one just to test the new one. Anyway it all worked fine up until one of the wires touched the metal on the inside of where the head unit sits.
This caused a spark then my head unit lost power or died. I automatically assumed it was a fuse so i replaced the 15a one on the back of the head unit and the 7.5a fuse under the kick panel. After doing this i still have nothing?
Im not sure what ive done wrong so maybe somebody has a suggestion to what i can do to fix this?
Thanks,
Mitch
Mzil
30
VY S Ute 5spd
check all fuses under the dash, pretty sure there is 2 seperate fuses for the stereo.
Hey mate thanks for the prompt reply! You are correct there are 2 fuses. The Second one which i have just replaced and still nothing :(
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
I know it's too late now, but the battery must always be disconnected or fuses pulled before any work like that is carried out.
Wire up your head unit to a separate power supply (with a fuse) and see if it works. If not........well.
If it does, you may have burnt out a wire.
With the H/U disconnected, do the fuses blow when you replace them?
ijoodz
47
greystanes
vz 2005 lumina
hi im jodie and i checked all my fuses everywhere my stereo still not working any other ideas plzz
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Is it the original stereo, or have you just fitted a new one and it's not working?
ijoodz
47
greystanes
vz 2005 lumina
also where is head unit in the car
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Ok... The head unit is just another name for the stereo/cd/radio in the dash.
If all the fuses are ok, I would suggest that there is maybe a problem with the unit it's self.
The fuses you should've checked would be......
Number 23 fuse
Number 11 fuse
Have a look at number 16 fuse as well.
