Wiring Loom?- where?
S2_VR_
Northern Rivers, NSW.
03' M6 VY SS ute
is it the metre long cord running behind the dash that plugs into the BCM???...
also can i run an Equipe BCM in an executive??......without the extra options??....
i am planning on running the extra options later, (power windows, etc) but i want to install the BCM now.
thanks guys
ephect
Donating Member
VS Acclaim V6
the wiring loom is the wire that runs from the engine bay to thru to under the dash, and then down the door sills and into the boot. there are plugs along the loom, but some is one piece thru into the bay.
yes you can run the equipe BCM in an exec, but u'll have to use the key that cam with the BCM or get a new key and have it coded to the new BCM, otherwise u wont be able to disable the theift deterent signal.
