Turd Ferguson
Donating Member
Parts Required:
WK / WL Indicators: Roughly $20 a side
Bulbs: $5 for pack of 2 from Repco
Before:
After:
1. To remove, push from the rear of the indicator forwards while pulling outwards. this can be tricky with the VY/ VZ indicators and you may find it easier to slip something underneath the indicator to help push it out
2. After the old indicator comes out, take note of which way the tab on the back faces then rotate the bulb housing until it comes free.
3.Take out the clear bulb and insert the orange bulb.
5. Screw the bulb housing back into the indicator.
6. To put back in. ensure the tab on the indicator is at the same end as when you took out the old indicator and push that end in. then push the indicator forward and in at the same time until it clips in. Ensure it is secure.
End result:
Before:
After:
End result:
