VT2Commie
- Jan 1, 2018
- 441
- 297
- 63
- Location
- WA
- VT2 Clubsport R8
Ok, I found out the brown wire is just the bare braid wire, (shield) for the camera video signal wires.
Have you got ALL the wiring from the donor 2012 IQ system, from the head unit to camera? Would help if you did.
GREEN CAMERA PLUG with PIN NUMBERS,
*PIN/WIRE 1, YELLOW - Video signal+
*PIN/WIRE 2, BROWN - "BARE BRAID" (SHIELD) for VID+/VID-. This is earthed through the camera so it doesnt need to connect to anything on the head unit side, BUT it must run all the way along WITH the YELLOW and BLACK camera +/- signal wires or the picture from the camera will get interference. (You need to have SHIELDED video wire), DONOR VEHICLE IQ WIRING ???
PIN/WIRE 3, WHITE - Reverse Signal.
*PIN/WIRE 4, BLACK WIRE (Closest to YELLOW WIRE) - Video signal-
PIN/WIRE 5, BLACK WIRE (Closest to WHITE WIRE)- Camera Earth.
PIN/WIRE 6, RED - Ignition voltage/power.
CONNECTIONS,
*PIN/WIRE 1- Goes to PIN 4 at Radio (PINK WIRE )
*PIN/WIRE 2- SHIELD, This is earthed through the camera so it doesnt need to connect to anything on the head unit side, BUT it must run all the way along WITH the YELLOW and BLACK camera +/- signal wires or the picture from the camera will get interference. (You need to have SHIELDED video wire), DONOR VEHICLE IQ WIRING ???
PIN/WIRE 3- Goes to LIGHT GREEN BACKUP LAMPS WIRING, tap into reverse lights.
*PIN/WIRE 4- Goes to PIN 3 at Radio (BLUE WIRE)
PIN/WIRE 5- Goes to EARTH, Any good earth point on the body of the car.
PIN/WIRE 6- Goes to IGNITION VOLTAGE, NOT the battery. Needs to turn off when ignition is off. Need to tap into a power source that is live when ignition gets turned on.
The PIN/WIRE numbers, 1/2/4, with the * next to them is the camera video wires,
Video signal+
Video signal-
Shield
GOOD LUCK M8.
CONNECTIONS,
Video signal+
Video signal-
Shield
GOOD LUCK M8.
