WM Grange Front Strut mount removal - MRC shocks
amys80
sydney
ve berlina
Does anybody know how to remove the strut mounts on a Wm hsv grange?
Done it before on a ve berlina, and clearly its not the same...
Any tips much appreciated!
Thanks
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
It's the same. Only you disconnect the harness from the back of the hub.
krusing
Melbourne Bayside 3193
Depending on why you are dismantling it,
Make sure you mark things that need to be placed back in the exact same position,
Use a centre punch,
and/or a black texta [only if the area doesn't need to cleaned with degreaser, which you will lose your markings]
Depending upon the repairs you need to do, you may need to get a wheel alignment after you re-assemble it.
