wont hold 2nd gear burnout
tbblitz
37
VZ SS 6.0 L
these are my mods.
stage 2 shift kit
mini spool
3,9 diff gears
extractors and exhaust
pod filter
i have a vs commodore v6.
i can redline 1st gear really fast then i hit second and it holds 4500rpm then slowly dies down low enough to hit first. what other mods can i do to fix this?
bigger throttle body? chip?
i think i only need a little more power because it only just doesnt hold it.
any tips on how to do it ? heat the tyers up more in 1st gear or ........
cracker
shitter tyres less people in the back line locker to stop the rear breaks
Dan355
Go THE SS's
Street Legal 355ci VN SS - Daily: VP SS
Locker for sure! Then go for power increase.
Raptorsc
RAPTR6
Cairns Qld Australia
www.raptorsc.com.au
Hilux 4.0 V6 SC 400kw
line loc the brakes and add more power, most of the problem is due to lack of power
3800VH
VH SLX V6
4.11 or 5.11 diff ratio
hoarey85
35
somerset, tas
VT Executive
I've got a VT and i can get decent cooks out of mine, but i only use the brake to start the burnout then i jus power skid and bounce off the limiter in 2nd, bout the only thing i have diff to you is YT High Ratio roller rockers there is a set on ebay if ya wanna have a look at em aswell as i have got some pic's in my ride i think? the links are below:D
H
Headpounder
Guest
off the topic here but i have a lot of modified engine parts on my VS V6 but it will not!! hold or do a burn out .whats the go with that .May be because i have ABS or just that i have new 18inch tyres on them??some help
BANGERS88
Hobart
1990 Toyota Starlet GT, turbo.
This might be a **** question but dont know much on Vt's, Do they actually have a rev limiter????
