wont start after engine bay wash
wildss
44
s.e melb
vnss
first up sorry ive chucked this here but i need ideas asap
car is a vs 5.0
it was running while i pressure washed the bay/motor
started washing the wheels and it just died on me
* there was no water near/inside the dizzy, pulled the cap off and checked
*no water on the coil
*ive pulled every plug and blew everythign out of them including the main engine harness plug
*cant even get it to start with aerostart down its throat
*suspected ignition module so chucked suspected faulty one in the vn but it works
*it has spark
*fuel pump primes
*plugs arent wet
*sometimes does a little backfire after cranking for a bit
*catalytic converter is a letting off some sort of smell if that makes sense
*we got it to run about an hour after washign but it ran rough at high revs and it had a flat spot then died and has been a **** ever since
even my mechanic mate has run out of ideas
im hoping its not the hall effect sensor in the dizzy- can this be checked if its working btw?
anyone care to share some other ideas?
jafo
lurker since 2003
59
adelaide
1999 wh statesman
sounds like you soaked the wiring and its shorting out somewhere let it dry out and see what happens
wildss
44
s.e melb
vnss
i dont have 3 days lol , i need it to be running by 5pm tomorrow
i like your theory tho
jafo
lurker since 2003
59
adelaide
1999 wh statesman
wd40 everything electrical
mavro
mavro
58
adelaide
www.mavromatis.nl
VX 5.7ss
pray and then grab a taxi.............
sorry had to do it...
good luck m8
arrow224
Subaru Liberty
Room big enough to fit car + car in room + massive heater = dry ?
Jecs
PAVTEK Race Engines
Staff member
'97 Caprice 355ci & VZ SS Ute
get a 2nd car, jumper leads, and keep cranking it till it starts.
happens when i wash the stato engine. it gets water logged. usually let it sit and polish the car and then try and start if still no go i drive the ute into the shed and hook the jumper leads. always starts after that.
Tsunamix
VT 2
Hmm..... 2 things spring to mind - Crank angle sensor - may be cracked allowing water penetration. If a tiny bit of moisture has got in you may get some odd resistance changes happening which means it's signal could be erratic. If it's got any grease on it afterwards it would seal the water in....
Clean it up and check it out.
Same deal with the throttle position sensor.
I guess it's possible that the O2 sensor has gone too, but the troubles your having don't seem to fit with what my mind suggests an O2 sensor could effect...That could mean my mind is wrong too :p
Pray like hell it's not a nick in the wiring loom somewhere allowing water into the loom, and randomnly shorting between some senosr cables (yes would also need a nick in the sensor cables inside the loom) because it would a pain in the almighties left trigger to trace it out and find it......
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
I dunno why u washed the car while it was running, electricals and water dont mix full stop.
I'd put it out in the hot sun for a day and see how it go's after that..
love the general
vy ss ute daily hj gts project
you could try puttin some floodlights on thereto create some heat and maybe dry it out like the painters use
