worked ve ss surging
BLAKE_7
vy ss
Hi Guys, i just bought a ve ss wagon... it's manual with this package
ECU Re-program Mafless Tune
• Performance Camshaft
• Dual Valve Springs
• Pushrods
• Trunion Kit
• ARP Balancer Bolt
• ARP Cam Bolts
• Penrite Motor Oil
• Genuine GM Oil Filter
• Penrite Coolant
• GM Crank Seal
• GM 3 Bolt Cam Gear
• GM Water Pump Gaskets
• GM Front Timing cover Gasket
• NGK Spark plugs
• CNC Heads
• Hy-Lift GM Roller Lifters
• GM Head Gaskets
• GM Head Bolts
• All labour to fit, tune and test
L98:
360kw (wheels)
long with all the usual bolt on's so I've booked it for a re-tune down at my local tuner Geelong Performance Centre in a few weeks time as it's carrying on like 6th gear is totally useless it bucks/surges it anything under 2000rpm and has a flat spot/misfire around 3000rpm, all the work was done by independent Motorsport in morwell who i hadn't heard of before but from what I've seen online ect they're well known ?
the cam is a 233/238 110+2 anyone run anything similar and have some drive-ability? Tuner said he'll have a go at it but might have to go something smaller cam wise..
thanks,
07GTS
Australia
VEGTS BUILT BLOWN E85
proper tuner will clean that right up simple as that just needs time spent on it to get it right
