Working a SV6 SiDi
Discussion in 'VE Holden Commodore (2006 - 2013)' started by CH3F, Feb 14, 2012.
  1. yxyx64
    yxyx64 New Member
    nsw
    Kia turbo + Holden badge, Chev badge in Texas
    Is there a before and after dyno chart that can be posted (there must be one or how else do people get numbers?) that will end the discussion?
  2. Jarp
    Jarp Surely You Jest
    VFII SSV A6 W375
    I've posted dyno sheets from 1st tune at CHE....ugly numbers but shows 20rwkw gain. This was prior to OTR and early in the tuning history. I believe the OTR and the MACE E85 tune make a vast difference. The Scanxl software indicates that it is putting out around 185+rwkw and 400nm fairly regularly. I can't say that is accurate but just telling you what I'm seeing. Here is the sheet thread http://forums.justcommodores.com.au/ve-holden-commodore-2006/155189-late-model-sv6-tuning-8.html
  3. CH3F
    CH3F New Member
    Adelaide, SA
    VE SV6 Sedan
    I believe the title of the thread is "Working a SV6 SiDi" not "I want heaps of power tell me the best way to spend my money"
    The cost all up is approx. just over $2000, if you can find me a VE SS that will out perform my SV6 for that price I might consider a trade...
    Or maybe you are saying I should just buy a V8 engine for $2000 and leave it on the garage floor?
    Thanks for your input though :)
  4. DECIMATOR
    DECIMATOR New Member
    VE SV6
    Just be careful putting an OTR on a SV6. It causes a lot of dramas with the MAFF sensor.
  5. Jarp
    VFII SSV A6 W375
    The ORSSOM OTR requires a tune when you fit it. MACE supplied a tune for mine no dramas.
  6. bigjim92
    bigjim92 Active Member
    2016 VF SSVR
    Fitting any OTR to a V6 or V8 will most likely cause issues with the MAF sensor, with a good tune you won't have to worry about anything!
  7. MACE
    MACE Well-Known Member
    We've never had an OTR on an SIDI we couldn't fix 100% :)
  8. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    Reckon someone needs to start making some replacement heads for the SIDI so you can bolt up some decent extractors...
    Surely someone could sacrifice some heads, machine away the forged headers and tap some studs... then sell them as exchange and repeat the process..
    good to see some working being done on the new engines though...
    aZk.
  9. samueljz94
    samueljz94 New Member
    Australia
    2010 Holden Commodore SV6 SIDI 3.6L
    i have a 2010 sv6 sidi with a few mods. yes they cost me but this was done over a year so here u have it guys :)
    orssom otr + custom dyno tune $1300
    25mm mace manifold spacer - $250 put it on my self
    mace engineering cams- $2300 + $950 to install
    2.5" Xforce Cat back - $800
    20% underdrive kit
    dyno dead stock made 154.4rwkw
    orssom otr 20% underdrive kit + mainifold spacer + dyno tune made 197.2rwkw
    go cat back done as a bolt on.
    got mace cams put in + Retune - 224.7rwkw.
    yes alot of money has been spend but worth it and i can drive it on P's ;)
  10. billy bob
    billy bob Member
    VE S2 SV6
    Next you need extractors and high flow cats.
    Then you might hit 250kw
  11. Kiddo
    Kiddo You're serious bro?!
    Mitsubishi Colt
    Ya'll do realise 75% of all workshop dyno sheets are fudged right?
  12. kuzman89
    kuzman89 Active Member
    vic
    VE SV6 ute
    A dyno is nothing more than a tuning tool. If it says 220rwkw for example then I don't doubt it makes that power on THAT dyno.
