@vs-lover Further to your comment above, !
I never said to use Castrol Rubber Grease where
@Vin999 mentioned the Red Organic Lubricate,
I then chimed in to mention the name of it, and now your saying not to use it, its 40+ years to late.
I have used the same rubber grease for 40+ years working on all cars when doing brake overhauls on Holdens, Fords, Honda, Mazda's
Some of the cars I have done a few times, I have also checked the condition of the calliper seals, as it doesn't take long to do,
Which is a good reason the blead the brakes to flush the old boil't/burn Brake fluid out, so its all been serviced, and has fresh brake fluid through the brake system.
With removing the pistons [carefully with compressed air] and removing piston seals, and dust seals/boots and cleaning them with degreaser, they still look as good as new, so I use the rubber grease to reassemble them.
Obviously if there appears to be a leak, you would install a service kit.
As far as I am aware, Callipers, Piston Seals & Dust Seals haven't changed in the past 40+ years that I can see,
and I haven't had any faults/issue's,
If anything, with using rubber grease, its make it easier to re-assemble,
and it helps the brake pad wear even, because the piston slides back easier, as it should,
which keeps the steering wheel straight under braking.
If you say it is a contaminant, how is this so ?
can you please explain to the JC Members your view on how its is ...........WRONG !
Maybe you need to inform Castrol of the same, they would be glad to hear your comments on their product.
https://www.castrol.com/en_au/australia/home/products/car/greases.html
