X Contact Dealer
mizzaa
46
Holden GTS 2006
Hey guys
Im looking for the mass airflow sensor due the the voltage low its on my HOLDEN 2006 GTS Ve...
I had the battery unplugged while I was working on the car finished my job, plugged it back in started strange then I had contact Dealer..
I have done a simple OBD check and came up with a few errors
P0102-00 Present Mass Air Flow Sensor Voltage Low
P0463-00 Intermittent Fuel Level Sensor 1 High Voltage
Any suggestions where to start? thanks
lmoengnr
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Hey guys
Going by Pic 2, you must have a MAFless tune, as there is no MAF fitted.
Better get it back to your tuner.
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
Did you disconnect the positive terminal, or the negative terminal?
Fu Manchu
WA.
Which did you reconnect first?
