I am thinking of going the 3" with 1 7/8" headers, so firstly is the 1 7/8" headers to large for a standard application (no internal engine mods, cams, head work and what not) or is 1 3/4" better?
Munz ^^ said it best, but to expand upon the detail... a factory VE SS requires an exhaust flow of 126-136 CFM (@ 28in), which is well within parameters of the supplied exhaust. The issue is not
restriction /
back pressure when running the standard tune, rather the main issues with the stock exhaust are
- The standard "log" headers provide exhaust port velocity (torque) at the expense of HP loss because the escaping gas velocity is almost too restrictive (fast), and flow (CFM) is definitely low.
- The standard "log" headers are generic cast, defined by GM as an integral part of the factory powertrain's tuned volumetric flow, yet is left unchanged whether the vehicle is a boat, airplane, truck or car.
In our application as a fast but heavy road car ideally the headers should be modified to maintain high velocity in the upper 200s FPS (hence torque), reasonably increase flow, and provide equivalent sound pressure waves back to the valves. This results in improved economy, torque, horsepower and basically makes the engine sing.
However the common mistake people make regarding exhausts (and primaries more critical), is supersizing pipe Cross Sectional Area because
race car noise... the automotive equivalent of strapping a fire hose to garden tap.
5300 | 1 | 1 1/4 | 1 1/2 | 1 3/4 | 1 7/8 |
Exhaust Port CSA | 1.608 | 1.608 | 1.608 | 1.608 | 1.608 |
Primary OD | 1 | 1.25 | 1.5 | 1.75 | 1.88 |
Primary CSA | 0.875 | 1.125 | 1.375 | 1.625 | 1.755 |
Exit FPS | 300 | 275 | 217 | 190 | 170 |
Result | Sonic choke with HP loss (too fast) | Recommended HP and TQ | Largest exhaust port exit (slow FPS) | Torque loss + Reversion + Scavenging Loss (too slow) | Torque loss + Reversion + Scavenging Loss (too slow) |
The ideal primary pipe size and headers for your car
with a stock tune are the factory headers. Go bigger without tune and overall performance will suffer, although it may sound better and feel like it redeems itself at peak rpm.
Also, are people with X-Force systems happy with their's or do you wish that you went with a different brand and if so what brand?
I am happy with X-Force now that I sorted the drone which pretty much all aftermarket catbacks have to some degree. I went for mild steel this time but next set will be aluminised or stainless with a different centre section.
I'll probably hit up a cat back system first due to funds and then move on to headers and cats.
Yeah good first move, a 2.5" catback may increase exhaust velocity (hence torque) slightly by marginally promoting flow, and perhaps HP however the primary restriction to flow (HP) is deliberately in the headers as it suits torque delivery in the standard tune. A 3" with standard headers won't do you any good, at least in performance terms as the pressure drop from skinny stock headers and cats means the exhaust exit speed at lower RPM is too slow.
Lastly just to make sure I don't need a tune with the cat back or am I better off doing the lot in one go so I don't have to have the car re-tuned?
No tune required with catback, not really required until you decide on a plan for better performance / efficiency. CAI & tune starts at $1250, at which point you should also consider replacing the stock headers for 1 3/4 tri-ys like I had. This will cost you an extra $300 installed and will make a big difference.
