xb coupe common rust areas
VL Berlina 5speed
Apprentice Panel Pusher
Project VL Show car, VS Exec, VY Ute, YZ250F
my sister friend has asked me if i was intrested in doing some work on his xb coupe
mainly just cutting out rust and welding new panels in
ive worked on many xy, xw and xb gt's at my old work but i cant quite recall where the common rust areas are on the xb's
besides the usal lower 1/4 panel behind the wheel and the back end of the seal panels
i think there was something along the firewall that usally started to rust out, can anyone else recall this??
i dont want to have to go there and not have him stripped all the areas i need so i can check what needs to be done
legendvs
vs berlina
they rust along the lower rear window,parcel shelf area, boot rubber channel, lip running across top of firewall/rocker panel, inner sill panels, area behind front guards (lower rear), radiator support lower, lower rear quarters (inside and out), doors, top of rear wheel arches, rear tail light panel. might be a few areas to start looking at.
VL Berlina 5speed
they rust along the lower rear window, parcel shelf area, boot rubber channel,
lip running across top of firewall/rocker panel, area behind front guards (lower rear),
inner sill panels, radiator support lower, lower rear quarters (inside and out), doors, top of rear wheel arches, rear tail light panel. might be a few areas to start looking at.
cheers mate, yer i knew there was some are in the firewall that usally started to rust,
although he has had it for many years and last i looked it wasnt to bad
suppose its up to him, does he want to only do the cosmetic rust or the hidden rust aswel
that lower rad support on the early falcons was asking for it, a boxed area with no/ample drainage:bang:
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
With XA's and XB's, anywhere steel is used rusts. I don't think there is a single panel on those models that doesn't rot out severely.
eurekamad94
street kiddo
qld
kitted, tuned, sick pantha VS
from memory the boot area, rear quater panels, and sunroof's (if fitted) rust quite badly but dont qoute me on those my knowledge is limited on coupes only worked on one a few times
VryNeat
perth wa
VL EXEC
your knowledge is limited on everything ur 14
jules
we like the bun
pimpin
they used cork to join the panels in those things, i had an XA coupe, rust everywhere..
greenfoam
VP Executive R-spec
I was just about to reply. On a XA/B/C Anything that's not plastic or rubber. But you've allready done it :)
