xf tb, which size?
hosedogg
vl sl 5spd 6 n/a turbo convert '88
hey guys, just wondering which one of the xf tb's would be better suited to a n/a vl ? the 68mm or the 80mm?
cheers for any info.
warney
did you say bukakki party
VL skid car what else are they built to do
urs will prolly be a 60mm or there abouts throttle body any ways i wouldnt bohter to change it
Stewart1000
work done by ME
34
vic
www.justcommodores.com.au
VL twin turbo. VN5L. old jeep, **** mondeo.
i didnt even knwo there was an 80mm on the XF's
the 80mm would be better but if you already have the 68mm on it yeah probably not worth making it even bigger because you wont notice much increase in anythign because the inlet manifold isnt big enough for the 68mm let alone the 80mm
hosedogg
i've only got the standard vl tb and i've been told that this one i should be getting pretty soon is an 80mm. when i put it on i'll be replacing the whole intake to suit, so it gets a nic even flow. cheers.
bangers
45
NSW
EL FALCON XR6
how are you oing to replace the whole intake? the opening on the plenum isn't big enough for 80mm to be of any benefit. the air flow is only good if the plenum can get it in.
hosedogg
by the intake i meant the intake piping not plenum, forget to wrinte piping. the plenum u just get a die grinder and take it out to the same size as the tb. i've read articles on how to do it. i was just wanting to know which would be the better size to use. i'm thinking the 80mm would be the better size.
bangers
45
NSW
EL FALCON XR6
the plenum won't have enough meat on it to grind out that far.
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
wy bother :wax: :wax:
hosedogg
only bothering because i can get the 80mm throttle body for free of one of my mates.
