yet another error code question :(
thekow
VX s2
I read up on the dash error codes , and after doing it on mine i got a unusal result and i cant find what it means
My VX commo comes up with
10 flashes , 10 flashes , 1 flash , 2 flashes (repeat 3 times)
WTF does that mean coz thats like code 110 + code 12 ?
if so what does that mean?
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
I've got no idea what that means, it certainly doesn't sound right.Try resetting your ECU and see if you get code 12, 3 times. Reset by disconnecting negative battery terminal for about a minute or 2.
TigerVX
2000 VX Commodore
I've posted the same thing a couple of times in the past year with no luck.
I get exactly the same codes. My car runs fine but I'd like to know what the code means.
Dr Bob have you heard of this?
thekow
VX s2
yes i reset the ECU (took the positive terminal off for about 3 mins) still does the same flash combination , did i reset the ecu right?
accentstencil
68
Eschol Park, Sydney
Yes you reset it right, so I haven't got any other suggestions except have it checked out if it bothers you. If your cars running ok I wouldn't worry too much.
One more thing, my workshop manual recommends disconnecting the negative battery terminal, probably less chance of doing damage.
thekow
VX s2
A new error just popped up ? this doesnt make sense either , the other day my engine light and tracion control OFF light came on and went off
when i checked the error i get , 5 flash , small pause , 7 flash , small pause, 1 long pause , 1, long pause (repeats) . Still doesnt match up with any of the codes ive seen
Misaprop
black betty
37
VE SSV
that sounds like the ABS module is dying... gradually you shall see those lights more often, if that is indeed the problem
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
how are you flashing these out?
TigerVX
2000 VX Commodore
I get the 110 code by bridging pins 5 & 6 in the port under the steering wheel.
Everytime I do it I get a code of 110 followed by a code of 12 and it keep repeating this sequence.
Resetting the ECU doesn't help even if I don't start the car after resetting.
Any ideas?
Doctor Bob
Grandpa
Retired
when flashing codes from the VX the 10 flashes indicates a zero & as VX codes are all 4 digits your code is 0012.... normal system operation
Rob
