SgtBundy
- Apr 29, 2009
- 3
- 0
- 0
- SVZ Wagon
I have an MY10 SV6 auto which has always been Holden serviced as per the schedule. Just prior to the 90000 service started making unusual noises which I thought were transmission related, but at the service I was told it was simply low on oil (they didnt elaborate on what, and I assumed it was transmission not engine oil). The day after the service I got a "check engine" alert - I wanted to bring it straight back but was told I needed to book in again which wasn't possible with work at the time. The alert went away in a day or so. Not wanting to cop a service fee for what could be nothing I let it go, but after a while it started coming back intermittently. The car performed fine though which led me to dismissing it thinking it was just a sensor or something that got loose in the service.
With it persisting around the 99000k and the noise returning I took it to a different dealer. Again the oil was down again (4L in 10000km) and the codes were P0008 - which they told me was timing chain related. The recommendation was to do the firmware change to widen the timings and do an oil consumption test. As they also did the 105000 service as well as replacing the rear brake discs as well as an ECU clean, I left feeling like Homer in the tyre shop and now knowing that screwed feeling is common to whatever Holden dealer you get serviced by.
Since then the car has been fine. My own oil checks seemed fine and the oil consumption test I was told it had not used anything.
In the last week 3 things happened - I renewed the rego for a year, I paid the last payment on the car loan for it, and the fscking check engine light came back at 110000km. Its gone away again, but the feel of the engine is off - it labours a lot more, it seems sluggish to build power.
I have read the other threads. Yes, I left the serving to Holden as per the schedule - as a consumer I should be able to trust in that. I also copped the lecture from Dad about checking the oil myself, but in 4 commodores its never been an issue. My only defence is as an IT guy I expect alerts to tell me things (like low oil).
What I am looking at is I only planned to hang on to the car for another year, looking to replace it with a VFII next year. I am really not keen to spend $3000 to do the chain replacement if it comes to that, especially as I now see on redbook that is 1/3rd the cars value. I am also not keen to get Holden to tell me its needed, because of course they will say it is. I also guess having this hanging over the car makes the trade in difficult. What I would like to know is:
- If I ride this out what is the worst case? Is the engine going to fail spectacularly or just come to a grinding limp mode halt? I would really rather just live with it if its an annoying warning until our finances are ready for a new car, but if there are risks to it obviously I need to do something earlier.
- How likely is this affecting MY10s? I see there are threads for it, but all the detailed information seems to suggest it was mostly on earlier VEs. Could Holden just be jumping to a conclusion because its a VE SV6 throwing P0008?
- I want to get an OBD2 reader to check these codes - is there any metrics out that that I can look for that might give a clue as to how bad this situation is?
Thanks.
Thanks.
