Flash Gordon
- Jul 24, 2017
- 20
- 6
- 3
- Age
- 61
- Location
- Queensland
- VZ Ute
Hi All, long time lurker, first time poster, so I'm hoping that some VZ guru will be able to help me out with an annoying intermittent starting issue. First off I found a post from last year that details a similar problem but there wasn't any detail on the final solution so I thought I would try my luck.
I go to start my 2005 VZ Storm ute, insert the key, red lock light goes out and other "normal indicator lights remain lit (handbrake, ARS, etc). Turn key and starter doesn't turn. With ignition left on computer screen continues running its diagnostics and first error message that flashes up is "very low fuel", then "service vehicle soon" then "fuel guage error - contact dealer". Locking, unlocking, depressing the clutch pedal numerous times and you still get the same result. Disconnect the positive terminal on the battery, leave it disconnected for 5 minutes then re-connect battery and she fires right up and fuel guage reads as per normal (half a tank in today's instances). Happened to me five times today and same process cured it all five times. Battery is less than 3 months old and everything else in terms of performance etc is normal.
Anyone been able to cure this problem ?
