Finally got around to installing LED globes
Ended up buying Narva part number 18407
Not cheap at $130 per set on sale at Supercheap Auto and needed 2 sets, although have since seen them for about $115 per set
But I figured going with a known brand and having the option of local return is good
And they seem to be rated at 2500 lumens per globe which is pretty good
And this is probably an honest assertion, they look at least twice as bright as the Osram Nightbreakers I had in there.
i didn’t bother with the canbus modules - these probably create extrs heat in the headlight unit...
I just interpret the ‘low beam failure’ message as ‘headlights now work better’
I’ve also adjusted the lights up a bit so the low beam cutoff is about bonnet height when facing a wall perhaps 30 metres away - should keep it below other drivers sight line.
When doing this I suggest adjust lights as high as possible using dssh control, then open the bonnet and use a phillips head to adjust up (likely) a bit more
Then if oncoming cars flash me (they haven’t) I can adjust down via dash control
i think this is about as good as you can get without adding more lights
And I would recommend it given easy to source, easy to fit, very noticeable gain, and even at $260 is not a lot for a $30k car.
And if you didn’t agree I’m sure you could box them ip and flip them on gumtree for at least 50 percent of your money back
All this said I would now consider the lights to now be perfectly safe for doing maybe 110 km/h on country roads where the halogens were good for only 80...,
If however one lived in the NT 10 years ago and preferred to travel at about 150 then better distance would be needed, which the factory reflectors seem unable to provide :-(
I have also fitted a 14 inch Narvs light bar behind the grille, and removed a slat to let the light out
This helps a little bit bit to fill out the overall beam but doesn’t really add any useful distance - it seems to be a combination of very wide spread and very narrow spot which is good for advertising but annoying to drive with
30 years ago now I had a set of cheap Narva 175 spots on my Holden Gemini which had non halogen headlights and as I recall the overall effect was better...
Admittedly my eyes are older but I still think the main problem is reflector size and design - a large diameter reflector and what is usually marketed as a spread beam is probably the most useful at semi-legsl speeds
Given at say 150 km/h the car is doing about 42 metres per second, and allowing a generous reaction time of 2 seconds, and a generous stopping distance of 150 metres, this would suggest one could pull up easily from 150 km/h if for example a cow appeared on the road 230 metres out. So a spread beam that lights everything up well out to 300 m should be enough...
So anyway my next project I think will be working out how to attach some large diameter spread beam spots
