Thanks for the heads up about the manual! I downloaded it and may well make use of it one day. But at present since it does not seem to have an index and I don't have enough time to scroll through 9000 pages I've had a look elsewhere also. Although if I was smarter I'd probably work out how to use the search function in the PDF viewer...
So anyway I had a look around on the net and came up with the following points...
1. We're only really talking about vertical aiming since (I think) the ZB does not offer horizontal adjustment. And the concern seems to be about blinding oncoming drivers, as opposed to not being able to see where we are going because the headlights are aimed way off to one side and waking up sleeping infants or marsupials.
2. According to Hella (below) there should be a drop of 10 cm per 10 metres for the low beam, or a 1 % drop, to ensure they are just below the horizontal. Which incidentally means that in the ZB, whose headlight globes are about 68 cm above the ground, the low beam should run out at about 68 metres. So trucks with the lights mounted higher up have a big advantage here...
Headlight adjustment | Beamsetter headlight adjustment tool instructions ✓ Video: Headlamp adjustment ✓ Setting light distribution ✓
www.hella.com
3. Hella make the point that for many years headlights WERE adjusted by shining against a wall 10 metres away, and that headlight 'beamsetters' have become popular because they can do away with the need for a wall, and 10 metres (or 15 including car) of flat floor. And that one can still use the wall method. I would suggest that if one wanted to be really accurate one could use a wall even further away, eg. 20 or 30 metres in an underground carpark, to check that the lights are a little below horizontal...
4. And that because the beam is measured much closer to the car with a beamsetter, the likelihood of error is much greater. Eg. being 5 mm out at 10 metres using a wall is just 5 mm out. But using a beamsetter at 50 cms and having a 5 mm error will lead to a 10 cm error at 10 metres, and 60 cm at 60 metres, which might be a reasonable following distance.
5. And that if the floor is not level then this can produce errors too. ZB Commdore wheelbase is about 2.8 metres. Per Victorian building regulations (below) floors may vary in level by 4 mm per 2 metres. So lets say 5 mm per 3 metres. Which means about 17 mm at 10 metres and 100 mm at 60 metres..... So if you were to go to a workshop and ask them to scientifically adjust the headlights with a beamsetter, you'd need to first ask whether their floor had been checked witha laser level, and what was the relative height of the floor 50 cm in front of the car, and under each of the wheels...
6. Then lets assume we do manage to adjust our headlights to be absolutely correct, with the car parked on a floor accurate to say 1 mm over 10 metres, brand new tyres, and exactly the amount of fuel and people that we will carry at all times. And then put some large people in the back seats and a week of shopping in the boot. Rear suspension sags by maybe 12 mm as compared to front. 12mm/2.8 metres means the beams have come up 42 mm at 10 metres, and a full 252 mm at 60 metres... This might be why the ZB has a little pot on the dash to adjust the headlights up and down...
7. Having read a bit about this a think a reasonably scientific take which could be useful in the real world would be to say:
- Low beam headlights are supposed to have a drop of 1 percent, so 10 cm at 10 metres
- There is going to be an unavoidable error of around +/- 17 mm at 10 metres due to most floors not being flat to wihin eg. 1 mm. So no matter how hard one tries, using the wall method, or a beamsetter, the stated aim is not entirely realistic. But using a longer distance will reduce error.
- One practical way to check whether the beams are above, at, or just below level would be to:
- Park car 2 metres from a wall in a large (and empty) underground carpark
- Put some sticky tape on the wall to show the low beam cut off
- Back up 10 metres, or even better 20 metres
- If the cutoff has climbed up above the tape then the lights are above level, if still on the tape they are level, and if below the tape then all good
- Would probably want to check on a number of different walls and average the results to allow for the floor itself not being level
- Doing nothing just means that we don't know if they are properly aimed or not
- Paying a professional to do it may well be a good solution, but after he (or she) has done it, it would still need to pass the wall test...
- Or even simpler, just pace out the distance to where the low beam cut off hits the road. If its about 70 metres in front of the car, then it MUST
be below horizontal, and the science suggests a drop of 10 cm per 10 metres is 68 cm per 68 metres. This might even be better since it is
measuring the drop over a much longer distance!
- And as it stands my headlights are definitely hitting the road well inside of 68 metres, which would be about 4.5 standard (in my area) house
blocks, as these are about 15 metres frontage
