GEM 13B
- Apr 26, 2005
- 4
- 0
- 0
- Location
- adelaide
- Daily vy clubsport rx7 1jz corona
hi,
i work at an exhaust shop and im doing research on the best possible exhaust for v6 commodores, to make the most power. typically we run some 3-2-1 extractors into a single 2.5" exhaust then into a 2.5" cat, a resonator then a straight thru muffler at the rear. now this whole system makes a noticable difference to the power but earlier today i was told about a different system that instead of going from the extractors to a single pipe then the cat, it goes from the extractors to twin 2.25" pipes into twin cats then into a single 2.5" exhaust. this set up is supposed to make 25kw at the wheels more than the single system!?!?! im not too sure about this as 25rwkw is a fair bit of power (approx 40hp more at the engine).
so my question to everyone is what type of exhausts are yous running and what sort of power are you making, bearing in mind that this was on a dead standard engine.
your input would be greatly apprieciated as it will go towards developing more powerful and better sounding exhausts.
thanks.
thanks.
